LaurK
Aug 15, 2024Aspirant
Model RAX45 Loose Antenna Mounts
Hello, my sister has a Nighthawk Model RAX45. They keep it at a shared vacation space and one time they found that two of the antennae were very loose and the mounts don't seem to be fastened down to...
Aug 16, 2024Guru - Experienced User
Your best best is if someone else has taken it apart or the fcc documents.
Here's some internal photos from the fcc.
https://fcc.report/FCC-ID/PY319400466/4871255
I'd probably just get some sugru for it and not worry about it
- LaurKAug 17, 2024Aspirant
Thank you for that link! It helps a lot. I was going to just glue whatever was broken back into place. Should take care of the two floppy antennae. Now, at least, I can see how it opens up. Looks like it is just the one torx screw on the back.
