roger159
Jun 02, 2024Aspirant
Modem issue
Hi all, I'm having issues setting up my TalkTalk D-link DSL-3782 router as a modem only. I have turned off wifi and DHCP on the D-Link but cannot get internet via wifi or ethernet after setting up my...
michaelkenward
Jun 02, 2024Guru - Experienced User
Try this:
d-link dsl-3782 bridge mode - Google Search
And:
User Manual D-Link https://www.dlink.com › dsl › dsl-3782 › manual
roger159
Jun 03, 2024Aspirant
Thank you Michael, I'll check your links out.
- michaelkenwardJun 03, 2024Guru - Experienced User
Good luck. DSL modem-only devices are getting hard to come by. Netgear got out of that market a few years ago. And many ISP modem/router boxes (think BT) do not support bridge mode.
There are other options, albeit more complicated. So come back if it doesn't work.
This might also help.
How to fix issues with Double NAT | Answer | NETGEAR Support
