hurry_arise
Jun 02, 2025Initiate
Most Service Ports No Longer In Stealth Mode
Greetings, I have the following NETGEAR product:
Nighthawk 4-Stream AX1800 WiFi 6 Router (RAX10) Serial Number:
All of my router's service ports used to be in stealth mode. Testing was done a...
- Aug 14, 2025
Sadly same issue here out of the first 1024 ports only 3 are stealth all other are closed.
(my RAX10 is on firmware version 1.0.19.172)
When i disabled the "protection engine" all ports do go stealth.
DTibs
Jun 06, 2025Initiate
I too have this on a RAX10 with most recent firmaware. A RAX10 with older firmware does not have this issue, what gives? I want full stealth on all ports, but its only on the first 100 or so ports. Please fix asap.
Thank you.
