rodriguezadrian's avatar
Apr 05, 2021
MR 60 Satellite Capacity
Greetings,
I bought an MK63 system a few weeks back and I'm interested in adding a third satellite. The system already included 2 MS60 satellites. Is it possible to add a third MS60 to the system? Does the MR60 support 3 sattelites at once?
  • plemans's avatar
    There's a KB article for orbi but I haven't seen one for the MK series. Might be beneficial now that there's the MK60 and 80 series.
    I've seen it posted of others using more than 2 satellites but I'm not sure of the performance hit you'd take past 2.
    Maybe Christian_R can help
    • rodriguezadrian's avatar
      rodriguezadrian
      If Christian_R or any other member can clarify, that'd be helpful. I want to be sure to see if it's worth spending $129 on a new MS60 Satellite.
      • plemans's avatar
        Its tough as there aren't many members that use or have used the mk system on here. either the mk60 or 80 series. So sadly there isn't many people helping out with it.
