Hovoqeri
Feb 22, 2021Tutor
MR60 - No option to assign local DNS server on LAN for Pihole
I'm trying to run PiHole on my LAN but the MR60 doesn't seem to have an option to assign a local DNS server. I've RTFM, I've searched the web. I need to keep the Raspberry Pi running PiHole and my NA...
Feb 22, 2021Guru - Experienced User
I use the same ip address as the pi.
If you're using ipv6, you'll also need to setup the ipv6 info with your pi-holes ipv6 address info in the routers ipv6 dns entry.
Hovoqeri
Feb 22, 2021Tutor
This worked, thank you! I didn't think to just add the same IP address for both primary and secondary. Much appreciated. There are some sources on the web that falsely state that Netgear cannot do internal (LAN) DNS assignment.
- antinodeFeb 22, 2021Guru
> [...] There are some sources on the web [...]
Thanks for the helpful links.
> [...] that falsely state that Netgear cannot do internal (LAN) DNS
> assignment.There have been some (many?) reports here that some firmware versions
on some models don't allow it. The fact that your device with your
(unspecified) firmware version does allow it is hardly proof that those
reports "falsely state" anything.
