69Skillzz's avatar
69Skillzz
MR60 and Nest Thermostat
So after hooking up my new Mesh router from Costco, my Nest thermostat won’t stay “online”. Nest thinks there’s a protocol issue and asked me to hotspot my phone, and connect Nest to phone to confirm. Sure enough, Neat stays connected to my phone hotspot but that’s not a long term solution. Anyway to get the MR60 to step down to a 802.11(b,g, or n) protocol to be compatible with Nest? Maybe on the guest network side perhaps?
  • plemans's avatar
    What modem/gateway is the mr60 connected to?
    What firmware is on the MR60?
    if you shut off the satellites for the mr60 system, does the nest stay stable?
    • 69Skillzz's avatar
      69Skillzz
      It is an Adtran 401 Gateway using Comporium Fiber.
      Router is on V1.0.6.110_2.0.49 firmware. Satellites on or off doesn’t change stability of my Nest.
      • plemans's avatar
        Have you tried setting the nest with a static ip address?
