Jaime10
May 24, 2021Tutor
MR60 Mesh Nighthawk how many devices can I connect?
I recently purchased this router. I read that you can connect 25 devices. I currently have 14 devices and plan to add the Ring alarm system which will add another 20 devices. I wonder if having 45 de...
May 25, 2021Guru - Experienced User
- Jaime10May 25, 2021Tutor
Thanks for the quick response. I looked at the link you sent me but I do not see the MR60 model listed in the list showing "This article applies to:
Not sure if it goes by a different model number or if it is a new model and the list has not been updated by Netgear. Should I assume that it also applies to my model?
Thanks again for your help.
