Mtylor's avatar
Mtylor
Mr60/ms60 5g stopped showing up after update
So two things, when I first installed the system I was able to connect to 5g wifi. After updating, the 5g vanished and my satellite has been cutting off completely to where I have to unplug it for a while and sync it again. Anything I can do other than factory reset and hard reset
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Mtylor,
    You may try reverting back to the previous firmware version to see if that helps.
    Christian
