Vector77
Dec 29, 2020Aspirant
MS60 satelites will not sync with MR60 router
I have the Nighthawk Mesh WiFi 6 System in my home. It was working fine until about 3 days ago. Now the MR60 router will not sync with the 2 satellites (MS60). I have gone through the process of push...
MINTXIL78
Feb 14, 2021Tutor
Hey all
I was able to finall figure this ridiculous problem out.
1. A few weeks ago the nighthawk app notified me up a firmware update. So I clicked update.
2. Didn't realize one of my satellites went out till later so didn't "connect the dots"
3. Turns out the latest firmware update V1.0.6.110 should NOT be uploaded on the MR60/MD60 router/satellites.
4. I went on netgears website and dowloaeded V1.06.102 and updloaded it to the MR60 router using the "routerlogin.net" access. Attached image to show where to go to upload.
5. After this upload everything worked correctly.
I spent many hours to finally figure this out. Had to pay to join "gearheads" for them to spend an hour on the phone with me to lead me to the same thing.
The feedback was that I should not manual update when firmware is available as there are issues with it working with this specific MR60 router. My feedback to netgrear is then they shouldn't have their apps alert me that an update is available.
Ultimately fixed it but disappointed I had to spend $90 and several hours with gearheads to fix something they shouldn't have released to the public in the first place.
Hope other can fix this issue with my
Gantala
Apr 09, 2021Aspirant
I had the exact same problem because my app was set to automaticaly update firmware and it had updated to V1.0.6.110, it was resolved following the intructions of MINTXIL78 and the rollback to V1.06.102. Thank you so much MINTXIL78!
