Lbodie
Jun 26, 2021Guide
Ms80 with wired satellite
I have the nighthawk wifi 6 with two satellites. I’d like to put one satellite at the other end of a wireless point to point network (ubiquit m5). Nothing I do can recognize the satellite AP. It’s har...
- Jun 28, 2021
Reason I say that is I've seen some of the green functions/managed functions cause issues with the orbi systems. It could be as well with many mesh systsems.
If its working without the point to point system, then I'd be checking some of the settings on the point to point system to see what could cause it. (maybe check with ubiquiti)
Or you might run into the same issue with whatever system you get.
Lbodie
Jun 28, 2021Guide
I don't. It works fine on the host side switch.
Jun 28, 2021Guru - Experienced User
