JoeKerr70
Feb 21, 2023Aspirant
Multi gig access RAX70
Not sure if this has been touched on, but I have Xfinity, with 1.2Gb plan. I'm avging 400-650mb download, RAX70 router with V1.0.13.128 firmware, CM2000 modem, TP-Link TL-SG105-M2 5port multi gig sw...
JoeKerr70
Feb 22, 2023Aspirant
It's a wired setup.
Kitsap
Feb 22, 2023Master
JoeKerr70 wrote:It's a wired setup.
And what about question number 2? Have you tested your wired speeds directly from the modem?
What device are you using to test your throughput capacity?
What application are you using to test your throughput capacity? Recommend the Ookla native operating system application available from the play store.
