rsun0525
Aug 29, 2023Guide
Multi-Gig Port (Port 5) only detecting at 1gb speed?
I have a RAXE500 where I enabled the the multi-gig port as the Internet uplink but for some odd reason it's only detecting the port at 1GB. When I plug a 2.5GB device into that same cable, it works ...
Aug 30, 2023Guru - Experienced User
What device are you plugging into the multi gig port?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
rsun0525
Aug 30, 2023Guide
One more question when I go into the Nighthawk app on my phone, under Settings, Router Settings, Internet Port, for "Type" is says Down, what does that mean? Is there a doc that details what the Types could be? Can't find any other setting in the mobile app or web configuration page that could be related to trying to get it to negotiate at 2.5GB
