Mark99's avatar
Mark99
Multi gig port setup for 10g switch
I have a Virgin modem connected to my RAX2000 internet port (yellow socket).  Is it possible to connect a 10gb LAN switch to the Multi-Gig 2.5G/1G ethernet port on the router to use 2.5G LAN?  If so,...
  • Mark99's avatar
    Mark99
    Jan 21, 2023
    Problem now solved, the 2.5gb multi-gig port does not work on my Rax200.  Defective ethernet socket, so cannot be used. Tried 4 different cables with direct connection to PC and router failed to connect. Looks like I need a new router if I want 2.5gb network!
