Mark99
Jan 20, 2023Aspirant
Multi gig port setup for 10g switch
I have a Virgin modem connected to my RAX2000 internet port (yellow socket). Is it possible to connect a 10gb LAN switch to the Multi-Gig 2.5G/1G ethernet port on the router to use 2.5G LAN? If so,...
- Jan 21, 2023
Problem now solved, the 2.5gb multi-gig port does not work on my Rax200. Defective ethernet socket, so cannot be used. Tried 4 different cables with direct connection to PC and router failed to connect. Looks like I need a new router if I want 2.5gb network!
Jan 20, 2023Guru - Experienced User
I believe there is a switch in the Routers web page on how that port is used.
I would presume that if the 10Gb LAN switch is backward compatible for 2.5Gb speeds if you set the RAX to use that port for the LAN side and if you use a good quality CAT6A STP cable, the connection should work. Though Id check with the 10Gb LAN switch to ensure its fully compatible and working with 2.5Gb speeds.
Mark99
Jan 21, 2023Aspirant
