coyote3
Sep 15, 2019Guide
Multi-Gig port to PC?
Can I connect via the RAX120's Multi-Gig port (5G/2.G/1G) to a PC, with say a 5G ethernet port, and get 5G?
- Sep 16, 2019Yes, it can be used as a LAN port.
coyote3
Sep 16, 2019Guide
Thank you very much, avtella!
The manual and product page didn't make that clear enough.
avtella
Sep 16, 2019Prodigy
It’s only a WAN (Internet side) port if you specifically select the 5gb port as WAN in internet settings, otherwise it acts as a LAN port. I have it connected to a 10Gbps switch (at 5Gbps link rate) which is connected to my NAS.
- coyote3Sep 16, 2019Guide
Very good to know, thanks!
Now the documentation (of it's default functionality) seems right after all.
- mrbartSep 16, 2019Aspirant
so can it do dual wan now? 1gb+1gb and output 2gb on the multi-gig LAN to pc? original firmware that wasnt possible
- Retired_MemberSep 16, 2019
I would have thought it would be able to LAG on the WAN side and LAG on the LAN side but was told it can not do this like the other AX routers.
