Atomicorp
Oct 22, 2019Aspirant
Multiple front-end IPs with RAX80
Our ISP assigned us about 13 static IP addresses, of which we're currently only using 1. We have the RAX80 router and were wondering if it supports using multiple IPs so that we can set up some hone...
- Oct 22, 2019
Not a single Netgear consumer router does support multipe IP addresses on the WAN side (resp. a WAN subnet) - this includes the Netgear BR500 "business" router btw, too.
Atomicorp
Thank you. Do you know offhand any Netgear products that do? I'm looking at the different business solutions but not seeing any that specifically state they support multiple WAN connections.
schumaku
Oct 22, 2019Guru - Experienced User
Well, beyond of the consumer stuff and the BR500 (or the Orbi Pro) there is nothing left active. Look elsewhere. For a small business look into e.g. the ZyXEL ZyWALL USG or VPN product line for example and add wireless access points ot the wired LAN. Avoid converted consumer routers btw., too.
