Rick43334
Apr 05, 2022Follower
Multiple Routers
I have two Nighthawk routers. One in the house, the second in the barn. The one in the house is connected to my modem. The router in the barn is connected to the router in the house via CAT6 (wired)....
Razor512
Apr 06, 2022Prodigy
Typically when you set up multiple routers, but keep the same SSID and password, you will get some benefits from 802.11k which can help a little with roaming, but the process is still largely client directed.
Client directed roaming varies by device. For smartphones typically unless it is rooted, there is often no control over roaming behavior than what the device maker defaults to.
On PCs, you will often have some control over how aggressively it will seek out a better AP. PS, the roaming behavior also takes into account your activity. If you are continuously sending data or receiving data, then some devices will stick to an AP for a longer time even if a better AP is closer.
The mesh products, even with a wired backhaul, will use additional roaming assists such as 802.11v and 802.11r, but ultimately the client device is still in control, if it is a sticky client, then it will resist attempts of the APs to move the device.
