Fieldzy's avatar
Fieldzy
Follower
Dec 29, 2020
Multiple SSIDs on multiple VLANs
Hi, I’m looking at purchasing a Nigthawk AX4200 and want to understand its capabilities.
I’d like to create an IoT network that’s separated from my main network by way of VLAN.
Is it possible to have two SSIDs on on the 2.4 or 5Ghz band each with its own VLAN and no routing between the VLANs?
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Fieldzy,
    You may contact our Pre Sales team to better assist you with your inquiry. Please see our Support page: http://www.netgear.com/support/contact.aspx Select "Get answers about NETGEAR products before I buy" They will be able to assist you in answering your questions for your network & security needs.
    Christian
