gusbream
Feb 13, 2023Follower
Multiple SSID's
Hello, Is there a product that allows for creation of multiple SSID's and for those SSID's generated, can you set granular controls for kids, gaming DNS etc? Thanks Gus
michaelkenward
Feb 14, 2023Guru - Experienced User
gusbream wrote:
.... can you set granular controls for kids, gaming DNS etc?
For that sort of thing, try parental controls.
Which products support NETGEAR Smart Parental Controls? | Answer | NETGEAR Support
Other devices support Circle:
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Circle also needs a subscription.
