Scg
Jan 25, 2025Guide
My AX5400 keeps for getting the names of my iPhones
I have had this router for well over a year and everything has been fine until recently. Now, all of the iPhones on my network have the same name of "Apple." They no longer have individual names. This...
Jan 25, 2025Guru - Experienced User
are you using private ip/mac address on the iphone?
- ScgJan 25, 2025GuideYes, the phone's were set up for rotating. I did not specifically do these settings so either they were done automatically in an upgrade or something has changed. I never had an issue with the router recognizing the phone names in the past.
I turned off the private networks and it seems to be working now. Thank you for your help- plemansJan 25, 2025Guru - Experienced User
Glad it was an easy fix
