pjd813
Aug 03, 2022Guide
My AX6000 simply does not work.
Does the AX-11000 suffer the same problem of constantly dropping connectivity over both WiFI and Ethernet? My AX6000 worked fine for two weeks and has been getting progressively worse over the last 4...
Aug 03, 2022Guru - Experienced User
What actual device do you have? AX6000 is a speed.
It could be you had a bad device.
I'd highly recommend looking through the reviews (not just the forums because thats where people with issues come) to see how well they last long term.
pjd813
Aug 03, 2022Guide
Hi,
Here is a better model # description. I have the RAX-120 and it does not maintain an internet connection at all anymore. The more recent reviews are almost uniformly terrible.
My question is about the RAX-200….. does anyone here know if it has the same issue?
- plemansAug 04, 2022Guru - Experienced User
I've got an RAX200 and when I used it, it worked great. I upgraded to the RAXE500 and then the RBKE963 so I haven't used mine in a bit but again, it worked well when I had it.
- pjd813Aug 04, 2022Guide
That’s promising…. If you don’t mind my asking- how long was the RAX-200 in continuous service before you replaced it?
It was in pretty constant use for probably 6 months?
Then I actually went to a mesh system, the the raxe/rbke
I try a lot of different systems.
