KelvinKKF's avatar
Oct 19, 2019
My laptop Cannot Find the SSID of my RAX40 router
All of my devices bar one can find the SSID of my new RAX40 router, but my laptop couldn’t... I’ve checks its network adaptor is Intel Dual Band AC3160... I’ve followed advices I’ve found online to i...
  • plemans's avatar
    Oct 19, 2019
    Intels wireless chips need to be on the most recent version to see the ssid.  Many people say they've checked the device driver but only use the automated driver checker or trust in the device manager to update it. this won't work with these ones as they won't recognize being out of date. You need to manually install it.
    Your driver needs to be on version 20.100.5.1 at the current time. You can open your device manager and pull up your wireless driver to see which version you're on.  Which one are you on?
    I'd recommend going to the intel website, download the proper driver, and manually install it.
    https://downloadcenter.intel.com/product/75442/Intel-Dual-Band-Wireless-AC-3160
