KelvinKKF
Oct 19, 2019Tutor
My laptop Cannot Find the SSID of my RAX40 router
All of my devices bar one can find the SSID of my new RAX40 router, but my laptop couldn’t... I’ve checks its network adaptor is Intel Dual Band AC3160... I’ve followed advices I’ve found online to i...
- Oct 19, 2019
Intels wireless chips need to be on the most recent version to see the ssid. Many people say they've checked the device driver but only use the automated driver checker or trust in the device manager to update it. this won't work with these ones as they won't recognize being out of date. You need to manually install it.
Your driver needs to be on version 20.100.5.1 at the current time. You can open your device manager and pull up your wireless driver to see which version you're on. Which one are you on?
I'd recommend going to the intel website, download the proper driver, and manually install it.
https://downloadcenter.intel.com/product/75442/Intel-Dual-Band-Wireless-AC-3160
KelvinKKF
Oct 19, 2019Tutor
Thanks! It works now!
Although I am still having difficulty in completing the set-up of the Nighthawk App.
Oct 20, 2019Guru - Experienced User
Are you able to log into it via the browser? Use a computer and once on your wifi or hardwired in, go to routerlogin.net from here you should be able to customize the setup. I prefer this method as it gives you more options when setting stuff up on your router.
- KelvinKKFOct 20, 2019Tutor
Thanks. For some reason, it suddenly works now...
I was able to login via desktop version of the site www.routerlogin.net, for what it's worth.
