Boombar
Mar 06, 2019Tutor
My laptop doesnt see my Nighthawk AX8 with AX WiFi enabled
One of my laptops doesnt see the router with AX WiFi setting on.
After i disable it it does see it.
Any suggestions of a workaround on either end?
What am i missing if i turn off the AX WiFi?
Boombar
Mar 06, 2019Tutor
I found this:
https://kb.netgear.com/000060384/My-Windows-device-is-not-detecting-my-AX-router-s-wireless-network-what-do-I-do
Laptop says it has latest adapters but i'll check manualy-
Still courious what happens without AX on.
Cheers and thank you.
