Boombar's avatar
Boombar
Tutor
Mar 06, 2019
My laptop doesnt see my Nighthawk AX8 with AX WiFi enabled
One of my laptops doesnt see the router with AX WiFi setting on. After i disable it it does see it. Any suggestions of a workaround on either end? What am i missing if i turn off the AX WiFi? ...
