Cryptogirl
May 27, 2021Follower
My netgear AX180 wifi 6 router unable to install with Spectrum all in one modem/router
I did everything in order. Rebooted and started again. Its not working. The message is "unable to join the network Netgear48" also, it does not show up as an option on any of my devices. Really fru...
antinode
May 28, 2021Guru
> My netgear AX180 wifi 6 router [...]
None of that is a model number. Look for "Model" on the product
label.
With that datum in hand, you might try this radical concept:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for the
LED descriptions and "Troubleshoot". Pay particular attention to the
"WiFi LED".
The RAX20 User Manual, for example, claims that "two buttons are
located on the front of the router", but seems to mention only "the WPS
button". If there's also a Wi-Fi On/Off button, that could explain some
kinds of problems.
Further reading might not hurt, either, but, with this quality of
documentation, I wouldn't bet on it.
> [...] with Spectrum all in one modem/router
Also not a maker or model number.
If you already have a "Spectrum all in one modem/router", then why
are you adding another router to the pile? (There are reasons to do it,
but what are yours?)
Also not a clear description of what's connected to what. (Hint: If
a device has different types of ports, then "connected to device" is not
enough detail.)
> [...] The message [...]
"The message" from what, when you do what?
> [...] is "unable to join the network Netgear48" also, it does not show
I'd expect something more like, say, "NETGEAR48", but only one of us
can see your product label.
Worst case: Get a computer with an Ethernet interface, and try again
with a wired connection to your (unspecified) router.
> Really frustrated.
Try to imagine what it's like for someone else to try and guess what
you have, what you're doing, and what happens when you do it.
