Warblingpants67
Jan 14, 2021Follower
My New AX4300 Is slower than the Mediacom Provided router
(Im not sure why exactly I cant find my model in the dropdown box, but here it is AX4300 6-Stream Dual-Band WiFi) My new router is much slower than the provided one (Old Router/Modem Combo). On th...
delesher
Jan 17, 2021Aspirant
After much searching it seems that the speed is limited at 2.4 Ghz on dual band routers, I assume so that more bandwidth can be dedicated to the 5 Ghz connection. I logged into my router (www.routerlogin.net), went to the Advanced tab, selected the Wireless menu option, then removed the check from Enable 20/40 Mhz Coexistance under the Wireless 2.4 Ghz section. My speeds changed for around 25 up to over 60.
