DannyLin
Aug 11, 2020Apprentice
My RAX120 Internet connection was disconnected frequently.
I bought my RAX120 just about 3 months ago and I'm happy with it. I also have a Netgear EX7700 extender in my living room. Recently, when I'm watching TV via my Chromecast (connected via EX7700 t...
DannyLin
Aug 16, 2020Apprentice
Christian_R wrote:Hi Danny,
Have you tried moving your chromecast to a different TV in your home to see if the issue persists?
Christian
Hi Christian,
It has nothing to do with my Chromecast bacause all connected devices (2 iPhones, 1 Macbook) are also not able to access the Internet.
I tried to switch it back to DHCP for a couple days. I don't seemed to see any connection issue anymore.
But then the Internet connection was disconnected last night.
I realise I will have to reboot my RAX120 to make it connected again. But before I tried to reboot, I checked my RAX120 log and something very strange.(attached)
There's a DoS Attack on port 443 and it is very close to the time that my Internet connection was disconnected. I couldn't find any setting that I can alter or fix this. I tried to not to reboot and see how it will go.
In about 5 to 10 mins after the "DoS Attack" timestamp, my RAX120 re-connect to the Internet again. I think my previous setting with PPPoE might be related to this as I remember I also checked my log and there're DoS Attacks as well.
Can you please shed some light on this?
DannyLin
Aug 18, 2020Apprentice
Hi Christian,
Allow me to add more info here.
So after I switched to DHCP, everything seemed to be fine. But it was once disconnected then.
I checked my settings and learned from a friend to turn off UPnP to prevent from port scanning and DoS Attack.
I tuned off my UPnP and all seemed to went well for a while. But the Internet connection was suddenly halted for a while (like 1 min), and I go check my logs, and there're some "DoS Attack: RST Scan" in my log and they seemed to be the reason to cause my Internet connection halted.
- Christian_RAug 24, 2020NETGEAR Employee Retired
Hi Danny,
May you send me a private message with your contact info again and I'll have support follow up.
Christian
- DannyLinAug 27, 2020Apprentice
Christian
Just private message you, Christian.
