40kfan2025
Jun 22, 2025Aspirant
My rax50 says internet connection is good. But wifi and cable connections to devices are not working
I have checked all my cable connections. I have called my ISP to make sure there are no issues with my fttp connection. I have made sure the router is successfully connected to my ISP by making sure ...
Jun 22, 2025Guru - Experienced User
Might run thur this and see if anything helps you:
Nighthawk Router Troubleshooting, Suggestions and Tips | NETGEAR Communities
