Trussman
Feb 13, 2020Guide
My RAX80 and nighthawk app problems.
Hello I’ve had this router now for 3 weeks. The past few days the nighthawk app has been saying it can’t find, connect or the router is no online. But yet all devices are connect. Is there an issue w...
Trussman
Feb 13, 2020Guide
I have an Arris Surfboad, stand alone router
Trussman
Feb 13, 2020Guide
Also on the Nighthawk app, it asks me to log on after it can’t find the router so I put in my Credentials and it doesn’t do anything. Very frustrating.
- plemansFeb 13, 2020Guru - Experienced User
What arris modem is it?
Try the setup using a pc or browser setup. I'm not a huge fan of the app setup process.
- TrussmanFeb 13, 2020GuideMy router is setup. The problem lies between the app n router it appears. Modem is a surfboard arris sb6183
- ablickleFeb 13, 2020Guide
I had a similar problem. Could not log in with app and when accessing router from computer it showed internet disconnected, even though it was online and working fine. Ended up disconnecting power at router and rebooting that way a couple of times, and now all is well again.
