RCNZ
Jul 27, 2021Aspirant
My router is RAX50 nighthawk and I wish to know if read cloud feature can be enabled on this model.
RAX50 — Nighthawk AX6 6-Stream AX5400 WiFi 6 Router
Jul 27, 2021Guru - Experienced User
page 113-119 of the manual go over usb storage setup/requirements/etc. If you get it setup properly, you should be able to connect to readycloud.
RCNZ
Oct 02, 2021Aspirant
Hi i have changed my router to RAX70 AX8 now within a week but readyshare feature seems to be a hoax...!!! shoud be in the router configuration.(just enable and download app )...not chasing tails....would have settled for a cheaper option
plemans wrote:page 113-119 of the manual go over usb storage setup/requirements/etc. If you get it setup properly, you should be able to connect to readycloud.
