ravallone69
Sep 28, 2025Guide
My router won't recognize my new 2Gig Wifi Speed
I have an Rax70 Nighthawk router. I just increased my internet from 1 gig to 2 gigs. I attempted to change the speed I got an error message. Unable to establish Wan aggregation. ( See Below). I h...
Sep 28, 2025Guru - Experienced User
This model router and most all RAX series routers sans RAX 120 and 200, will not support any ISP speed past 1Gb. The WAN/LAN ports is maxed at 1Gb so most you'll ever see on the wire is around 900Mpbs. Wireless anywhere from 300 to maybe 700Mpbs max on 5Ghz AX.
If you need to see speeds past 1Gb, RAX120,200, RAXE500 or NGs new wireless7 RS series all have 2.5Gb or higher speed WAN/LAN ports.
