ravallone69
Sep 28, 2025Guide
My router won't recognize my new 2Gig Wifi Speed
I have an Rax70 Nighthawk router. I just increased my internet from 1 gig to 2 gigs. I attempted to change the speed I got an error message. Unable to establish Wan aggregation. ( See Below). I h...
CrimpOn
Sep 28, 2025Guru - Experienced User
The RAX70 Product Data Sheet appears to suggest that it supports port aggregation on both the WAN and LAN ports:
From the User Manual:
From page 30:
It would help to know the model number of the modem to see how the WAN port and LAN port 4 should be connected to support port aggregation.
- ravallone69Sep 30, 2025Guide
The modem is an Adtran supplied by United Communications
Nothing on Modem. Label has the following:
SDX631q
XGSPON ONT
PN: 1287944FI which I'm guessing is the serial #
Thanks for your help. If no solution,
I think I'll buy WiFi7 I'll wait till next week and see if its part of prime days
- FURRYe38Sep 30, 2025Guru - Experienced User
Let us know what you end up with.
