slicket2001
Apr 20, 2021Aspirant
My wifi HPENVY 4520 printer wont connect to my netgear rax10 wifi router help
just purchased new wifi router RAX10 AX1800 WIFI 6 ROUTER, now my wifi hp envy 4520 printer will not connect to this router. It recongnizes and will display connection and then it will drop. any advice, i have tried just about everything.
- carapungoAspirant
besides this printer issue, are all other devices connected to the router?, if they are, then the issue is with the printer itself, try to configure the printer with a dedicated IP address.
- slicket2001Aspirant
yes all devices connect-the printer though will flash back and forth that its connected and then not its, not sure how to config the printer with a dedicated IP?
- carapungoAspirant
I have the HP Envy 7640 printer. All i did was to run the wireless setting configuration, connect to my wireless access point, enter password and printer became on line.
Does the wireless indicator on your printer is solid blue?, if it is, you are ready to go, if it's not, then you nned to do more troubleshooting.
Does your printer have a USB port?, if it does then you may want to use the Share option in Genie
here:
