slicket2001
Apr 20, 2021Aspirant
My wifi HPENVY 4520 printer wont connect to my netgear rax10 wifi router help
just purchased new wifi router RAX10 AX1800 WIFI 6 ROUTER, now my wifi hp envy 4520 printer will not connect to this router. It recongnizes and will display connection and then it will drop. any advi...
carapungo
Apr 23, 2021Aspirant
I have the HP Envy 7640 printer. All i did was to run the wireless setting configuration, connect to my wireless access point, enter password and printer became on line.
Does the wireless indicator on your printer is solid blue?, if it is, you are ready to go, if it's not, then you nned to do more troubleshooting.
Does your printer have a USB port?, if it does then you may want to use the Share option in Genie
here:
slicket2001
Apr 25, 2021Aspirant
I have followed all steps to connect to the wifi router-nothing is working. The blue light blinks, not solid. I have had this printer for 3 years and its worked great on my prior netgear router. All devices at home connect to the new router except this printer. Printer does not have a usb port (.
- slicket2001Apr 25, 2021Aspirant
additionally, my computer recognizes the router.
