Cdb1018
Mar 28, 2020Aspirant
My Xbox has been having serious problems
My Xbox will not stay on port 3074 and performs horrible online. I have tried port forwarding but it didn’t solve anything. I can get it on to port 3074 but when I go back into settings it switches to...
Cdb1018
Firmware is V1.0.4.46_10.1.63 and I have spoken to Microsoft and my internet provider and they both mentioned port forwarding.
Mar 28, 2020Guru - Experienced User
Why? What issue are you having?
And what modem are you using?
- Cdb1018Mar 28, 2020AspirantThe online performance has been really bad, basically unplayable. I don’t have it connected to a modem.
- plemansMar 28, 2020Guru - Experienced User
the router is running off something. Its hooked to something. Whats it hooked to?
what speeds do you pay for?
What speeds do you get hardwired into the router?
Is your xbox hardwired in or wireless?
- Cdb1018Mar 28, 2020AspirantIt is only hooked to our Ethernet cable and an outlet for power. The Xbox is wireless and I have not tried wired
