Jannestig
Oct 20, 2020Aspirant
NAS not appearing on Wirless network but appears on LAN
Hi all, I upgraded my router recently to RAX80 and have a number of device connected,
I am running 2 PCs on WIN 10 1 can see the NAS RN214, I can see it it on the Wired connection but not on the wireless connection either on 5g or 2g. However i can connect using the ready cloud app where it give me not 192.xxx address but something like 55.xxx
I can still see other devices including wired devices and another NAS across the wirless pc and instantly see the NAS when i plug in the wire
I have turned off some of the feature on the RAX80 i was playing with like QOS.
The NAS is using a bonded ethernet connection into the aggregate port of Router,
So i am trying to identify where the issue is
Wirless PC network settings
NAS shared on Wireless
Router sharing requirements for wirless haring
Thanks, It was something i had configured in the router (unsure what) i reset the router to factory settings and all services appeared, not to say there isn't a bug involved !
> [...] RAX80 [...]
Firmware version? Connected to what?
> [...] I can see it it on the Wired connection but not on the wireless
> connection either on 5g or 2g. [...]"see"? "it"? "the wireless connection"?
As usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.Do you mean that a shared file system served from the RN214 does not
appear on your Windows system when that Windows system uses a wireless
connection to the router?Does Windows consider that wireless connection to be "Private" (good)
or "Public" (bad)? Windows file sharing is normally inhibited over a
"Public" connection. (You don't normally want everyone at Starbucks to
have access to your files.)
> I can still see other devices [...]"see"? "ping" and file sharing follow different rules.
That's my first guess.
The NAS has no idea how your Windows system is connected to your
router.> Router sharing requirements for wirless haring
The router has no interest in how your NAS communicates with anything
on your LAN, unless there's a "guest network" involved.- JannestigAspirant
