TorwaK
Oct 03, 2019Aspirant
NAT loopback and SNMP reads
Hi all, Can you please let me know if NETGEAR Nighthawk AX12 12-Stream Wifi 6 Router-RAX120 supports NAT loopback feature and SNMP reads for mrtg readings? Thanks!
schumaku
Oct 03, 2019Guru - Experienced User
TorwaK wrote:Can you please let me know if NETGEAR Nighthawk AX12 12-Stream Wifi 6 Router-RAX120 supports NAT loopback feature
NETGEAR Router support for NAT Loopback Note: The text list is incomplete, check the "This article applies to: " ChristineT please ensure the KB entry will be updated.
TorwaK wrote:SNMP reads for mrtg readings?
There is no SNMP on Netgear consumer routers available.
- TorwaKOct 03, 2019Aspirant
Thanks for the reply.
The article has been updated on 2018. So it would be great if someone from the support team confirms AX12 is featuring NAT Loopback functionality.
