ThomasPape
Oct 08, 2020Initiate
Nat loopback or Hairpinning on RAX40
I have a Synology NAS on my LAN, and a static IP from my ISP that is bound to a public domain name. Everything works perfectly out of the house, with port forwaring and security certificates and all....
antinode
Oct 08, 2020Guru
> [...] RAX40
Firmware version?
> Does anyone know how to set it up?
I've never seen a Netgear router model where there's anything to set
up. It should just work. However, bugs in Netgear router firmware are
not uncommon. For example, this problem has been reported repeatedly in
the D7000v2:
https://community.netgear.com/t5/x/x/m-p/1566171
Regarding the D7000v2, responses from Netgear "support" tend toward
"it's not supposed to work", but when your model appears in that KB
article, that claim might be tougher to maintain.
You might also check the specific forum for RAX models:
https://community.netgear.com/t5/x/bd-p/en-home-routers-nighthawk-wifi-ax6
