axaxax
Sep 11, 2024Aspirant
NAT loopback stopped working (RAX30)
I have been happily using my RAX30 to access a server on my home network, but yesterday it stopped working. I can access the service using a local IP address, but when I use its public domain nam...
- Sep 11, 2024
Of course, as soon as I posted this I found the problem!
NAT loopback was working fine, but the local IP address of my service had changed, so my port forwarding rule was pointing to the wrong IP.
I have added an address reservation under LAN Setup to prevent this happening again.
Sep 11, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
