axaxax
Sep 11, 2024Aspirant
NAT loopback stopped working (RAX30)
I have been happily using my RAX30 to access a server on my home network, but yesterday it stopped working. I can access the service using a local IP address, but when I use its public domain nam...
- Sep 11, 2024
Of course, as soon as I posted this I found the problem!
NAT loopback was working fine, but the local IP address of my service had changed, so my port forwarding rule was pointing to the wrong IP.
I have added an address reservation under LAN Setup to prevent this happening again.
axaxax
PsyonicOne
Sep 12, 2025Tutor
Hi axaxax
How did you set up NAT loopback on the RAX30? I can't find it anywhere!
- CrimpOnSep 12, 2025Guru - Experienced User
NAT loopback is automatic. Nothing to configure.
- PsyonicOneSep 12, 2025Tutor
Thanks CrimpOn
