Bomin3615's avatar
Bomin3615
Follower
Sep 13, 2020
NBN Australia Compatibility
Wanting to purchase this new cable modem to use with Telstra NBN.
Does anyony have any experience on this subject?.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which flavour of NBN?
    Getting stuff to work on NBN can be a nightmare. The good news is that a lot of people have already grappled with the challenge. So there's a lot of past experience that you can draw on. For example:
    Search - NETGEAR Communities – D6300 NBN
    You can try narrowing that down by plugging the name of your ISP into the search. Some ISPs have especially exotic configurations.
    Search - NETGEAR Communities – Telstra NBN
    The problem is that NBN comes in many flavours, effectively it just means "Australian Internet".
    What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
    Start by checking for your type of NBN.
    While Netgear lists all manner of things as being "compatible" with NBN in that article, in reality this often means that the device will work as a router. You have to bypass the modem bit and use something else as a modem. Sometimes it is just the NBN box that your ISP installed.
    Here's a good place to start looking for local expertise:
    “NBN” - Whirlpool Forums
    Good luck, you may need it.
