JN37
Aug 04, 2020Tutor
NBN connection issue
My router does not connect with NBN Got the RAX as it was the most recommended router on the market. My provider (iinet) helped me change router settings, but it failed every time it had to do the ...
- Aug 13, 2020
Worked it out.
My provider asked me to add VLAN when I went to Vlan/bridge settings in advanced.
I tried to edit the one that was already there instead.
Voila! 9 ping and 46.67mps.
Happy as larry.
Christian_R
Aug 10, 2020NETGEAR Employee Retired
Hello JN37,
Welcome to the community! If you recently purchased the device, I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket with support by registering your device using the link below.
https://www.netgear.com/support/default.aspx
Christian
- JN37Aug 10, 2020Tutor
Thanks Christian,
Opened ticket on Aug2 as my ISP (iinet) informed me that it was something to do with the router, as we unsuccesfully followed netgear directions to connect router to internet.
First response ticket was on Aug7 and it was a standard check your cable stuff, still waiting for next reply.
In Melbourne in lockdown, so I am dying to get it up and running.
This is what I have been doing but it is not working.
https://help.iinet.net.au/how-set-netgear-nighthawk-rax80-nbn-fttp-wireless
Let me know if anyone has a solution.
cheers
JN37
- JN37Aug 13, 2020Tutor
Worked it out.
Happy as larry.
