JN37's avatar
JN37
Tutor
Aug 04, 2020
NBN connection issue
My router does not connect with NBN Got the RAX as it was the most recommended router on the market. My provider (iinet) helped me change router settings, but it failed every time it had to do the ...
  • JN37's avatar
    JN37
    Aug 13, 2020
    Worked it out.
    My provider asked me to add VLAN when I went to Vlan/bridge settings in advanced.
    I tried to edit the one that was already there instead.
    Voila! 9 ping and 46.67mps.
    Happy as larry.
