fhuillier
Mar 15, 2021Aspirant
Neatgear EAX20 AT1800 mesh extender clignote orange depuis plus de 36 heures
Bnojour j'ai un Netgear EAX20 AX1800 Mesh extentender. Apres installtion il a redemarrer en mettant a jour le firmaware. Cela fait plus de 36 heures que celui-ci clignote orange sur la 1ere led e...
Mar 15, 2021Guru - Experienced User
sounds like it might have gotten corrupted during the update process.
You can try a factory reset by pushing and holding reset while its powered on for 7-15 seconds.
If that doesn't work, you can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
fhuillier
Merci pour toutes vos solutions malheureusement aucune des options n'a fonctionnées.
Il part en SAV.
Cordialement
