jacksappeow
Mar 27, 2021Follower
Need Coverage for AX6000 WiFi Router (RAX120
Hello, I need Nighthawk 12-Stream Dula- Band Wifi 6 routerwith 8 bps adding with Mim and USB 4.0 ports what is the covrage this device is providing ? And is it secure for data sharing? Please Guide
1 Reply
Are you asking about the RAX120? AX6000 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.Is the Model: A6150|AC1200 Dual Band WiFi USB Mini Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
