Rustyfoxx
Apr 18, 2019Follower
Need help connecting
I keep getting this same message when I try To connect to the WiFi router for the first time so I can finish the setup process. Keeps saying error opening page
Apr 18, 2019Guru - Experienced User
One the modem is activated follow this procedure.
1. Power on modem. Wait a couple minutes for it to fully boot and connect
2. Plug router into modem. Power it on. Leave it for a couple minutes to fully boot.
3. Plug into router or connect to router to do setup. Always recommend hardwiring in for setup/activation.
does it work?
