DSperber's avatar
Feb 22, 2024
Need help getting remotely located R6700AX router added to my phone Nighthawk app "products"
This is like a comedy of errors.   (1) ISP uses CGNAT, so port forwarding on the router does not work. I am in California and remotely connect to the computer in Florida using RealVNC which require...
  • DSperber's avatar
    DSperber
    Mar 08, 2024
    Ok. I have emerged victorious.
    As I described previously, I bought a second R6700AX and had it shipped directly to me in LA so that I could pre-configure it properly using both the Nighthawk app on my phone for "wizard" features available to the app, as well through the web browser UI for the more complex configuration required (i.e. static IP, as well as MAC address reservation for a fixed LAN IP address, as well as port forwarding to that fixed LAN IP address for RealVNC), for its eventual home in Florida running under Hotwire Communications.
    The pre-configuration also includes declining any subscription or trial period for Armor, as well as checking "do not bother me ever again" to get rid of it permanently.
    And I also set up a refund for the first R6700AX so that when the second one arrives and is swapped in, the net cost will only be for the one final router.
    So just yesterday the pre-configured second router finally arrived in Florida and was swapped in. WORKED PERFECTLY! And today the first router was dropped at a nearby UPS store and I've already received the refund.
    And, in fact I am now able to connect directly to the router in Florida through my phone in LA using the Nighthawk app:
    And furthermore, the No-IP DUC client once again works perfectly, not that Armor is not blocking the No-IP URL:
    Case truly closed!!
