Piejack
Nov 17, 2021Aspirant
Need help port forwarding
I have a Nighthawk AX4, AX3000 Model RAX35. I need help port-forwarding port 44158. When I try doing this, I get the message, "The specified port(s) are being used by other configurations. Pleas...
Nov 17, 2021Guru - Experienced User
Is uPnP disabled before you set up a PF/PT rule?
https://kb.netgear.com/000053857/Enable-Port-Forwarding
You might try configuring Port Triggering for that port #:
https://kb.netgear.com/000038518/How-do-I-enable-port-triggering-on-my-NETGEAR-router
