Piejack
Nov 17, 2021Aspirant
Need help port forwarding
I have a Nighthawk AX4, AX3000 Model RAX35. I need help port-forwarding port 44158. When I try doing this, I get the message, "The specified port(s) are being used by other configurations. Pleas...
Piejack
Thanks for your reply!
1.What Firmware version is currently loaded? How do you find that?
When I was on the Netgear software I clicked the 'update' button, and it said there was no firmware update available.
2.What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? The modem is a Comcast modem.
3. Is uPnP disabled before you set up a PF/PT rule? No. probably not. What is uPNP?
